Hi Gunter,
Here is the text, modeled with the extrusion angle you pointed out in your last file.
I used the centerline from the original file I posted that i got by converting a Vcarve toolpath into geometry. I flattened it and then set it at the depth of the tool you posted. Then just hand modeled the sidewalls to simulate an extrusion...They are solids. But they won't help you in Vectric..
Anyway........
