CNC engraving text in sterling silver
10542.10
Gunter, Burrman is correct...the bit geometry is determining the depth so it can accomplish the run. That goes back to what I first mentioned about centerlines (stick fonts) rather than offset/uneven fonts. The use of flat depth will restrict as you mentioned but if you do not want a flat bottom that doesn't help you here. You could modify the font to be performed in different mill runs
