Spiral _FGraph3D
10530.7 In reply to 10530.1
Hi Zooen, if the rest of the curve is how you want it and you just want to smooth out that one area you could try trimming away some space there and then cut the curve into 2 pieces also using Edit > Trim and then put in a blend curve using Construct > Blend.
