How to create large round edges if fillets don't work.
10526.7 In reply to 10526.5
Thanks a lot for the ideas.
Yes, the guitar bodies are complex.
It takes some creativity, particularly when the radius needs to change from large to small as at the edges of the pocket heel at the back.
The large radius at the back needs to stop in the cutaways where the direction of the curve changes towards the neck.
From there it needs to change into a small radius of about 2mm along the edge/nose of the heel.
I finally found that to get this done a few temporary replacement solids are needed. The brown part to get the large radius
and the gold one to get a small radius along the pocket heel.
The transition from the large radius to the small one succeeds by creating a network manually
It is still work in progress.
Thanks again and best regards from the Netherlands,
Ellio
