How to create large round edges if fillets don't work.
10526.1
Hello,
I'm not yet an expirienced Moi3D user looking for some indications on how to get a 15mm rounded edge on a bass guitar body with top and back body contours.
So far I managed to create the contours in the body solid. The arm rest contour on the front by cutting with an angled plane.
On the back by using a loft between two curves.
The fillet tool does not work on the points of the cutaways with a desired 15 or 12 mm round edge, which is obvious since the point curve radius is too small to allow a radius of that size.
The radius should become smaller where the height on of the body gets smaller in the area of both contours.
On the back at the blu arrows the 15mm edge radius should chnge to about 3mm at the edges of the heel.
I suppose that the circumference should be subdivided at points where the radius should vary.
My first serious Moi3D project was to create .stl files for 3D CNC milling of some bass necks which worked well with putting together a few solids and various networks in the transitions (see pictures)
By using Estlcam to create the 3D cnc code milling resulted very well.
Best regards from the Netherlands,
Ellio
EDITED: 13 Dec 2021 by SLIDING
