History → Script?
10518.5 In reply to 10518.3
Hi d4u,
> Given that is the idl file posted somewhere here up to date for the 4.0 API set?
Sorry actually no it isn't. Part of the rewrite to make v4 a true cross platform code base changed how the script interface is implemented internally and it no longer uses a moi.idl file to generate COM Automation interface code as it did before.
The overall focus for MoI is on being a simplified and streamlined CAD program that is easy to use and fluid to operate. Script writing is not really contained inside of that target area and so it doesn't get as much attention as work that is included in the main target goal.
If script writing is a major focus for you, you may be better served by a different program that has it as one of its main targeted areas unlike MoI. Rhino could be a good choice.
At some point in the future I would like to devote more effort towards scripting. I'm not sure when that will happen though there is still other work that has higher priority.
