Save image from MOI
1049.36 In reply to 1049.35
Hi rosto,
> Is there a solution to change the line tips to rounded like in Illustrator?
Not with this particular method since it's using the realtime viewport display engine which is heavily oriented for speed.
But you should get rounded line tips if you generate a drawing by exporting to PDF, AI, or SVG formats instead of using this screen display capture method.
