Hull design (Supply Vessel)
10486.1
General purpose Supply Vessel 33.75m X 9.15m X 4m plans are made using MoI.
Hull curves are very basic. Only 7 of them are used (the 8th in the picture is for aft profile). MoI will "Loft" them for your
After some work curves are faired "Rebuild" and ready to be used as FRAMEs. At the origin, the are obtained using "Intersect" function.
There is 12 control points for each frame curve and they are verified individually.
Details are important to give an idea.
A view from the aft
Surface can be rebuild to verify if it is clean. This one is rebuild using "Loft" based on faired curves.
EDITED: 21 Oct 2021 by ERYON
