Automatic installation of Moi3D on Linux
10477.6 In reply to 10477.5
Hi pafurijaz,
> and as it says here it needs IE7
The thing that says that is from 2007, that's 14 years ago and is no longer correct. That was for MoI version 1 and version 2. Starting with version 3 MoI does not require IE7 anymore.
> but every time I update WineHQ and open Moi3D I have to wait for the
> installation of the two components otherwise it won't start.
That's something built in to the standard Wine version, I think since those pieces are large it will prompt you if you want to install them or not. You don't need to install those for MoI to run, it does not use anything from Mono or gecko.
All you need to run MoI is to install standard Wine, no optional components, no gecko, no Mono, no winetricks are required nor are used by MoI.
The other piece that you need though is a good video driver that isn't full of bugs.
