Modeling a lure - some tips
10476.3 In reply to 10476.1
Without having the 3DM file, it's hard to see why Flow is not working out.
You could try this technique below. I've used it to place a raised strip of variable width chrome trim down the length of a car body.
1) Draw 5 curves to represent each extrusion of the lower-right gill.
2) Select the 5 curves.
3) Construct > Curve > Project > Select the top, front, or right projection as required.
4) Select the fish as the Projection Target.
5) Now your 5 curves are formed to the surface of the fish. These will be used as Rails for a Sweep. Make 10 appropriate sized closed curved profiles (one at each end of each curve for a taper) and Sweep each Rail.
6) Mirror the swept gill solid objects to the opposite side and Boolean Union the 10 strips to the fish.
A variation of this technique would be to project just a two curves (Rails) and design two closed curve profiles that include the ridges to make all 5 gills. Then perform a 2-Rail Sweep.
Something similar might work for the large gill behind the eye. I also think a Network might work to create the fish while integrating the large gill, all in one go. Would need to have your file to test.
EDITED: 9 Oct 2021 by EDDYF
