Detach Selection?
10464.13 In reply to 10464.9
Hi morph3us,
> All I can say is that I imported a step file (which I exported from FreeCAD, I dont know
> which program the model came from originally) and the backplate of my device was
> on the same object layer as two totally separate buttons.
So that's a bug, it's not intended that it should work that way.
> Unfortunately I can not share the file I am working on, is there a log I can show
> you or something?
Unfortunately no, there isn't any log that would help me to figure it out, I really need to be able to test with the actual file to fix file import bugs.
For now for your particular situation you could fix it by selecting the object that has disjoint pieces in it, then use Edit > Separate followed by Edit > Join, that should end up separating the disjoint object out into individual objects.
If I was able to reproduce the problem over here with a test file then I would be able to fix it for v5.
