MoI Trial Version Question with Scripts and Commands
10448.6 In reply to 10448.5
Hi Dave, you have added them to the correct place, it is normal behavior that you don't see any changes in the UI. You can launch a command you have installed by either pressing Tab once to put focus in the XYZ input control and then type in the command name there, or set up a shortcut key to launch it.
There is a description of this on the FAQ here:
https://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
> As I mentioned to Pilou, have seen screenshots of different folks interface and it has extra
> buttons at the bottom for such commands and scripts. This is what I'm looking to duplicate
> for quick easy access.
Those extra buttons are not part of the standard MoI UI, they are added by a UI mod called CustomUI which you can get here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
