MoI Trial Version Question with Scripts and Commands
10448.3 In reply to 10448.1
Hi Dave, no there isn't any limitation in the trial version for this. Maybe they are not in the folder that MoI is expecting, can you show a screenshot of what your folder structure looks like?
Also it's normal that with most plug-in commands that you won't see anything change in the MoI UI, you generally need to set up a shortcut key or type in the command name to launch a plug-in command.
