Flow and add points issue
10438.5 In reply to 10438.4
Hi Matadem, you can't show points on a solid where the "underlying surfaces" are not made up of the same points where they have a joined edge.
There is some additional description of this on the FAQ here:
https://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
If you use Edit > Separate to break your object into individual surfaces you should then be able to show points on the separate surfaces.
