Move a hole?
10435.2 In reply to 10435.1
You can select the solid with the holes, then execute the Separate command.
After this you can use Show Pts to show the points of the separated surfaces, select points, move points, and when all is done you can use the Join command to turn everything into a solid again.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
