Hi Necko, I have a new patch available here: http://moi3d.com/beta/Sep4_patch4.zip , this contains a fix for the PDF import problem.
To install the patch, download it and unzip it to get a new moi_lib.dll, then copy that new version over top of the older one in C:\Program Files\MoI beta Sep-4-2007\ .
After that MoI should load your PDF properly, and hopefully any others that you generate in the same way. Please let me know if you run into any other problems reading PDF files, it helps a lot when you send the file for me to test like you did here, thanks!
