Hi NaN, dimensions in MoI are independent objects and there isn't any way to link them to an object.
However, as Pilou shows above if you're going to transform an object by moving or scaling it, select the dimensions along with the objects and let them be moved and scaled as well. Dimensions will update their displayed value when they themselves are scaled, unless you have overridden the dimension text to a fixed value.
