issue with style/coloring after export and open
10426.17 In reply to 10426.16
Hi Pior,
> All I am saying is that there should be at the very least a warning about it to inform users
> *before* downloading/installing the beta, otherwise it can end up being a bad surprise for
> experienced users who would otherwise be happy to bughunt and provide feedback on a
> beta version but are wary of this kind of shared *.ini situation, exactly as I am.
A warning like that would seem strange to me.
The v5 final version will also have this same behavior of using the same moi.ini file so that
any customized settings for your environment are automatically used.
Does that mean that the final v5 version should also have a warning?
I don't know how to phrase the warning in such a way that it's not pretty weird, like
"Warning this new version of MoI will behave the same as previous versions of MoI".
A lot of people would read that and react something like "What? Why is that bad?".
In general I try to avoid baffling the user with things like that.
There has never been a bug like you are describing where the moi.ini file was
completely trashed by a beta release and unreadable by the previous version.
It just doesn't really make sense to warn about some hypothetical bug that has
never happened.
> like potentially loosing shortcuts and scripts and having to go back to a backup if the uninstaller
> went a little to far) while in a rush to finish a job on time ... :)
The uninstaller will not erase your shortcuts or scripts, that's also worrying about a hypothetical
bug that is not an actual problem.
