lightwave export and units
1042.4 In reply to 1042.3
Hi Nathan, I am trying to avoid making very many changes right before V1, but this one happens to be a pretty easy one.
I don't have LightWave over here though, so can you please test it to make sure it works properly?
You can grab a new patch from here: http://moi3d.com/beta/LWO_units_patch.zip . That will unzip to a new moi_lib.dll file which you need to copy over top of the old version in C:\Program Files\MoI beta Sep-4-2007\ .
Then you need to open up the moi.ini file with a text editor like notepad. You should be able to find the moi.ini file here: C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
Add these 2 lines to the very end of the file:
[LWO]
ScaleToMeters=y
With that stuff in place, then when you export to LWO your objects will be scaled to be converted into a meters unit system inside the LWO file which it seems like LightWave was expecting. Please let me know if this seems to be reversed or doesn't work as expected...
Thanks!
