Group Selection
10417.3 In reply to 10417.1
Hi Bo, you can type in object names using wildcard characters in the XYZ input box to select similar named objects.
To do that type the Tab key first which will put keyboard focus into the XYZ input box at the bottom of the window.
Then if you type for example HEADLINER* and push Enter all objects that have a name starting with HEADLINER and followed by any characters will get added to the selection.
You can also use ? to match just one character, like LAMP_? would match LAMP_X and LAMP_Y but not LAMP_XY .
