Hi Burr, I think the problem there is when you're clicking on the base and target surfaces you're clicking too close to the corner of the surface.
You need to click a little distance along the edge, not right at the corner. That's because it's the nearest edge to your click that will control how the surface match with each other. If you're right at the corner you're not controlling which edge is being used.
