Merge and edge
1041.3 In reply to 1041.2
>>right now you can use Join on surface edges to create a new joined stand-alone curve
Yes, I know... I just forgot to take it into consideration :)
>>I have thought a bit about having a separate "Merge" operation
Do you mean the "Merge" operation would combine a separate edges or curves that share the end and also a surfaces which share an edge? There is a couple of another merge-like command in Rhino, so if you grouped all of them into one MoI command (and of course, added some extra one :), it would be very cool!
>>(P.S. - I'm not sure if I have mentioned it before, but you can use Trim on an edge to do the equivalent of SplitEdge).
You did so.
Petr
