How to set all pallets open at once
10408.2 In reply to 10408.1
Hi simon, they should only snap shut if there is not enough vertical space for them to be open without a scroll bar appearing.
It's designed to have them collapse instead because it's better to have their header available to see and be targetable with a click without any scrolling. With scrolling you'll have some things not visible at all until you scroll.
Although I don't recommend it, if you would prefer to scroll instead you can set that up by modifying the file SidePaneTabs.js, find the function:
function CompactPaletteHeaders( HeaderToIgnore )
and add a return as the first thing inside it so it looks like this:
     return;
That should effectively disable the palette compacting but you'll have a worse problem with scrolling needed instead.
