Setting a new Edge Color and restoring within a script
Hi Michael -
I'm developing a script + HTML that I'll share when complete. So far it's working very well.
The icing on the cake would be to set Edge color within the script, do some stuff, then restore the user's original Edge color.
I'm able to use:
//Set edge color as defined by Fixed Color under Options > View > Edge Color
moi.view.edgeColorMode = "FixedColor";
//Set edge color as defined by Style
moi.view.edgeColorMode = "ByStyle";
But the script needs to use a specific Edge color for all edges. I'm trying to avoid having the user go into Options > View > Edge Color to change the Edge color before using the script.
So is it possible to change the user's "FixedColor" to a new hex value, then restore the original color at the end of the script? (Don't want to use a color picker)
If so, I'm good to move forward.
Even better if this is possible:
If user has a Style set up called 'TempEdgeColor' for example, set Edge color to that Style color. (Or maybe the script creates the Style if it doesn't exist?)
If no such Style exists, set Edge color to a hex value defined within the script.
Do some stuff ...
If the user had Edge Options set to "FixedColor", then restore Edges to that color.
Else
moi.view.edgeColorMode = "ByStyle"; // Restore Edge color based on Style
To say it another way:
The script wants to use a specific Edge color for all edges (overriding the Option " Edge Color" if it's set to "FixedColor"), do some stuff, then set Edges back to their original color.
Nice to have, but not required > If the user wants to use their specific color, then the user (or script) could possibly create a new Style to define a temporary Edge color for the script to use.
Finally, set Edge color back to the user's original color.
Again, trying to avoid having the user go into Options and make a color change if possible.
Or maybe there's a different, easier way that I'm blind to :)
Regards,
