Snap at intersection of line and arc?
10399.4 In reply to 10399.3
Hi Andre, sorry no the radial snap used for the arc drawing snap doesn't have any relation to that type of tangent snap. That would need a new mechanism in the point picker to do that so it's not something that can happen by adjusting a command script like the previous one.
There are a couple of different ways you can get the result you want there though, one way is by drawing a helper line from the center of the circle and then snapped perpendicular to the line. That will give you an intersection point at the spot you need:
