Snap at intersection of line and arc?
10399.2 In reply to 10399.1
Hi Andre, that was an oversight that the ArcCenter command did not do the setup stuff to enable that kind of intersection when the radial intersection mechanism was added to the pointpicker.
If you update your MoI installation to use the attached version here that should fix it. This ArcCenter.js file goes over place of the original one inside the application's commands folder.
