V4 scripts
10397.7 In reply to 10397.6
Hi Andy,
> Ok not quite sure where theses scripts go in V4 Moi on a Mac OS-10.14.6 been hunting for a while now
> I cannot find application support or appdata within MOI folders
Unfortunately Apple has decided to hide the Application Support folder to make it more difficult for people to do stuff with it.
In Finder you can use the "Go to Folder..." in the "Go" menu and put in ~/Library/Application Support/Moi/commands and that should get you to the right spot. Note the ~ (tilde) symbol at the start, that's a shortcut for your home folder inside /Users.
There is another "Application Support" folder off the root Library. You don't want that one you want the one in your user folder.
You can also use Cmd+Shift+. to temporarily show hidden files, or use one of the methods mentioned here:
http://osxdaily.com/2016/12/12/show-user-library-folder-macos-sierra/
