V4 scripts
10397.2 In reply to 10397.1
Hi Andy,
> Do the old scripts still work in V4 ?
Yes like 99% of them do. There are a few that needed minor updates.
> Where do you put them now / which MOI folder if they still work ?
You can put them inside the app's "commands" folder same as v3 but v4 also now supports putting them into a central location in appdata.
The appdata method is better because new MoI versions will find them there and you won't need to copy them around again.
The commands appdata folder for Mac is at ~/Library/Application Support/Moi/commands . I recommend to put them in there.
> Is there a compiled list of scripts created - I used to have a curve rebuild / Ionic volute or spiral script [I forgot
> to save my old scripts when deleting V3 Moi - Doh!]
There is on the "Resources" page: http://moi3d.com/resources - look for "Burr's script archive" and "Max's file archive".
> Also is there a simple non techy list of changes and updates to get a quick overview
> of what to look out for in V4 from V3 ?
I've been meaning to finish that up. There is some info here though:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10083.114
