Dear Michael! Dear friends.
The question is: is it possible to make folders in the list of objects? When there are a lot of objects, it is insanely inconvenient to work.
Moreover, the folder tree has long been "by default" in such programs as photoshop, illustrator, 3Dmax, blender, etc., etc.
Below I propose such an option (it can be implemented differently, of course). But it would be cool!
Perhaps there is already such a plugin for MOI3D, but I don’t know about it?
It would be very cool - for example - if you could select a folder and immediately select all the subobjects in it.
From the impossible (?) But also actual.
For example, the folder is named "Trunk".
When placing an object in it (dragging it into a folder), a prefix with the folder name was added before the object name.
Trunk
Trunk_Nut
Trunk_Latch
...etc
And the second point.
Now many people use 2, 3 monitors in their work.
Is it possible to add a property for additional windows to the interface so that they can be transferred to 2 monitors? Thank you!!!
ps. Is it possible to add the function "export dimension lines" when exporting to PDF or AI?
Sometimes this is very important, but now the export takes place without them, only objects. It is sad ;((
