Purchasing from V2
10392.4 In reply to 10392.3
Hi Steve,
> So to clarify, am I safe to click the following link ?
> Moment of Inspiration v4, upgrade version (requires v3 license) ($100 USD)
Correct, if you already own a MoI v2 license, you can click the link that says "Moment of Inspiration v4, upgrade version (requires v3 license) ($100 USD)" and order the discounted upgrade version instead of the full version.
You will then receive a v4 upgrade license.
When you install the v4 upgrade license, in order to run it will need both the new v4 upgrade license and also a previous version license as well.
It will find the previous version license automatically if it has been previously installed on the same computer, otherwise on a brand new computer where an older version of MoI has never been installed on you will need to enter in both the v4 upgrade license and also your v2 license as well.
You won't need to install v2 you'll just need to put in the v2 license key as well as the v4 license key.
> and that will definitely upgrade me to from V2 to V4? although it indicates
> Moment of Inspiration v4 Upgrade Version (requires V3)?
Correct, you will receive a v4 upgrade license.
The upgrade license will require a second license key from a previous version in order for it to run.
The previous version license can be from any previous version, your v2 license will work.
Thanks, - Michael
