Flow direction issue
10387.7 In reply to 10387.1
Hi Jabber, upload ability has not been removed but there is a size limit of 50MB per user, if you have filled that up then go to Options on the top bar, then Attachments on the left side and delete some of your previous attachments to free up some space.
For the flow direction problem, the locations where you click on both the base and the target surfaces is significant and controls how the directions are matched.
There is some information on this in the Flow help file topic, pay special attention to the part that says this:
quote:
For non projective mode, the locations that you click on both the base surface and target surface are significant and control how the horizontal and vertical directions of each surface will be matched to one another. You need to click nearby an edge of each surface, towards the start or end of the edge. The pattern will be rotated and reflected as needed to make the picked locations match with one another. If you do not click each surface with care it is easy for unwanted rotations to happen. Following is a visual example for where to pick.
