Sweep fails
10385.8 In reply to 10385.4
Hi Andre,
> but instead I'd like MoI to interpret the two curves as one profile and generate two solids, keeping
> their respective distance from the rail. Not sure if that is possible though.
Sorry no currently that's not possible to do in one single run of the Sweep command. The sweep command is expecting multiple profile curves to be at different stations along the path curve, so that the profile can morph between those curves as it travels along the rail. It isn't set up to have multiple profile curves all at the same position on the rail.
Doing a boolean union on the curves before the sweep will have no effect since they do not intersect each other.
In the future I'd like to make some way to set this up how you were expecting, maybe by grouping.
