Telephone cable
10382.4 In reply to 10382.1
Hi Tony, you should check out those tutorials above but the fix for your case there would be to use Flow just on the path curve and then do the sweep, instead of doing the sweep first and then the flow afterwards.
That would then avoid the compression and expansion that you have noted.
