Rotating in the Perspective viewport
10378.6 In reply to 10378.1
Hi Metin, if you set the construction plane to the view direction then the rotate command would rotate in screen space. There's a script here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2599.8
or this variant:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10112.9
> It would be very convenient and powerful if this would be possible, preferably
> with the addition of a 'trackball' rotation mode, rotating the object across multiple
> axes at once by moving the pointer around.
This style usually isn't done in a CAD program because it is imprecise to just map some arbitrary amount of pixel distance to an angle.
