Rotating in the Perspective viewport
10378.4 In reply to 10378.3
Metin -
Yes you can rotate an object in the 3D Viewport.
The trick is you first have to select the curved rotate handle on the Edit Frame while in one of the other views, then switch to 3D view. You'll then have dashed lines surrounding the object that allow rotation in 3 axis.
