Rotating in the Perspective viewport
10378.1
Hi Michael et al,
I'm wondering: is there an easy way, or is it possible at all, to rotate an object in screen space the Perspective viewport?
I've tried switching the Perspective view to orthographic mode, but no rotate / scale gizmos appear, and the Rotate command seems a bit cumbersome to use in the perspective viewport if you have snapping turned off, but maybe I'm using it incorrectly.
It would be very convenient and powerful if this would be possible, preferably with the addition of a 'trackball' rotation mode, rotating the object across multiple axes at once by moving the pointer around.
Thanks!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
