Pre-Sales Question
10373.8 In reply to 10373.1
Hi Sam!
Sure! I believe MOI 3D would be a very good choice for that! ( I was able to recreate your box/container geometry in MOI in matter of minutes! ( take a look at the attached file)
Note_1:In MOI 3D every thing is built around speed :-) So, for your box if you make top part and side part you can quickly mirror top/and side part to get bottom and other side part! By assembling them you are able to get your back part just by drawing a box and extrude it ( until now you would have a simple extruded box with height of your desired final box and width of it would be equal to width of your desired final box needless to say it thickness is equal to thickness of your plexi sheet you want to cut your box out of! ) in next step you put this raw box on the place your back part would rest; then you can perform boolean subtract operation and subtract top+bottom+sides from your raw box! and there it is! your back part! ( in a matter of seconds well maybe few minutes)
Note_2: if you assign a short key to below script you would be able to select a face and quickly extract outline of the selected face! ( that would help you to quickly get the outline of your back part for your laser cutting project!) MOI is able to save files in DXF format and to my knowledge most laser cutting machines can read that format! :-)
script: /* Select edges v1.4 */ var gd=moi.geometryDatabase, so=gd.getSelectedObjects(); function ss(o,v){o.setProperty("selected",v)} function sl(o){ for ( var i=0; i<o.length; ++i ) o.item(i).getEdges().invertProperty("selected");} gd.selectLoop(); sl(so.getFaces()); sl(so.getSolids()); sl(so.getOpenBReps()); sl(so.getSingleFaceBReps()); ss(so.getBReps(),0); ss(so.getFaces(),0);
Note_3: Recreated box is based upon the image you sent! therefor the holes are missing! The gaps that would be created due to laser cutting in not calculated! and my estimation is that the dimensions of your box are approximately as follow: 98 mm by 120 mm by 30 mm (Or 3.85 inches by 4.72 inches by 1.18 inches)
EDITED: 17 Jun 2023 by DRILLBIT
