Is there any way to switch drawing tools on the fly ? Specifically Polyline <> Interpcurve
10362.2 In reply to 10362.1
Hi Pior, there isn't a way to switch commands on the fly but you can make straight lines without leaving the control point or interpolated curve commands.
You do that by holding down the Ctrl key when placing a point which will make a corner point. If you make 2 corner points in a row you will get a straight line between them.
