stl export problem
10358.1
HI, I am facing a problem with stl export.
The original model in MOI looks like this
It is an extrusion of a profile and union with other objects.
Originally the longest edges were “straight” (no rounding)
I wanted to extend it a bit and make rounded, so I added solid cylinder and made a union.
Despite the union is OK, the .stl export produces false faces (faces inside the solid object)
The strangest part is, I cannot repeat the procedure how I made to union, I just remember I selected 3 objects at once and run union.
Attached is the strange solid and it’s stl export.
Until now I fully thrusted to the stl export, I had never such issue (exported hundreds of complex models).
The consequences are “fatal”… The 3D printer slicer does not recognize the false faces, but the slicer routine is confused, and creates wrong layers (partly missing layer) and it causes faild prints
What have I made wrong?
Is it a problem with .stl export?
How to prevent making mistakes in design leading to such strange behavior?
Thanks you in advance for answers :-)
Jozef
