Blend problem
10338.4 In reply to 10338.3
Hi sandykoufax, I think you're running into just a display glitch where you're getting a rough display mesh.
Try going to Options > View > "Meshing parameters" and set the checkbox for "Add detail to inflections" to be on. Does it clear that up?
Also even without doing that if you do a mesh export it should look ok there, it's just a problem with the display mesher.
