Hi Andy, well yes actually I find marketing distasteful and have tried to get away with as little as possible. It is unusual but it has worked out fine for me. If you have a good enough and different enough and useful enough product that stays around for long enough you can get enough word of mouth to do marketing.
I will probably be doing a little effort towards regular marketing at some point here though.
> It's like going to the hardware store. When you go in do you go straight to what you
> need and leave? Or do you browse around to see what they have so that in the future
> when there is a problem to solve you know a solution exists at the hardware store?
Well the case here is more like you're going into a super gigantic hardware store that has a lot of items on the shelves that were custom built to solve just one person's specific problem or workflow use case.
If it takes a long time to browse through those things and you don't want to spend that time then the solution is just "don't do it".
Like I said I do want to make a plug-in browsing system which would do what you want here. LIke many things it will take time to work on it and I haven't been able to get to it as of yet.
