Hi Andy,
> What does it matter why I wanted to explore the possibilities of MoI?
Because you're complaining about it. It's helpful for me to know if you're complaining about something if there is an actual reason for or not.
I can understand that it may be fun to explore every possible use of MoI but I'm more focused on doing things that help someone's actual work they are trying to do, not so much on just endless exploration.
> Well first of all looking at Chipp's tutorials it is impossible to follow along what he is doing without it.
Ok, then what I'd recommend is not looking at Chipp's tutorials while you are still a beginner. Those are something you can dig into at a later time when you've already gained proficiency in using the main areas that MoI is currently focused on.
> I wanted to see what it could give me and how it could improve my experience.
The problem is you are prematurely trying to improve your experience before you've actually gained experience in the regular primary targeted use of MoI.
In the future I do want to improve the process of discovering and installing add-ons. I'd like to make something like a "scripts browser" that would let you browse through a centralized depository and install by some button or checkbox control or something like that.
It will take quite a bit of work to do that so I'm not sure when it will happen. Currently it is not a top priority.
