How make this into a solid??
10311.3 In reply to 10311.2
Thank you for your reply! Here she is. Honestly, I don't know what happened. It started out as a Revolve, which created the basic spindle hull. Then, successive Boolean operations removed the after cut out and the hangar bay area. Iso created hull lines which were then used to create radials and length wise boxes which were them Boolean Removed to create the panel lines. Somewhere along the process, it became a hollow surface. I can't figure out how that happened.
Bob
EDITED: 23 Nov 2024 by APTIVABOY
