Setting the default number of array copies
10302.2 In reply to 10302.1
Hi Metin, the default value for ArrayDir can be set by editing the ArrayDir.htm file inside the commands sub-folder in the install.
It's on line #45:
					<td><moi:UnsignedIntegerInput id="NumItems" default="5"/></td>
Set the default="5" to instead be default="3" and it should then behave like you're asking.
