Does Curve 3 points show Tangent mode?
10300.62 In reply to 10300.58
hi Psygorn,
> I meant it would be good if I could draw a curve and then have it tangent to
> both the desired point of the line and the circle.
It's not really good for something that is used very rarely to have a special command for it because that's how the UI gets very bloated and unwieldy over time.
So it would need to fit in to an existing command. Currently I think it might be problematic to try and fit this into the regular circle/arc tangent command because there isn't currently a way in the command to specify tangent to a curve and also through a point on the same curve.
