MOI5 Wish list
10289.42 In reply to 10289.25
'Quite often after creating the object from curves I want to do some operations using edges. And as I have curves in the same area I have to hide curves first. This quickly gets annoying.
In Rhino we get a little pop-up when there are multiple objects in the same place so the user can pick the desired one. That, or some setting which would allow you to define priority (for example edges over curves) would be great.'
Revit has a function where you just hit 'tab' and it cycles through the objects the mouse is hovering over. I miss it in other softwares...Very very handy, quick, and yes far less intrusive than the Rhino pop-up...
- Rich
