MOI5 Wish list
10289.4 In reply to 10289.3
Hi Salvatore,
> The latter option is ok if you have only one piece that you can move around in the model
> space, however, I had over 20 pieces.
Ok, but I don't understand why moving 20 pieces is a problem. If you select the 20 pieces you can move them all together.
> Not sure how this can be sorted out in MOI. Perhaps being able to set a custom origin
> like 200,40,0 could be a solution?
I could set it up so that if you set a construction plane (View > CPlane) that it would use the construction plane's origin as the page origin instead of only using the world 0,0,0 origin point.
