Hi Alex, if you turn off the "Center on page" option, does that do what you need?
With that option off, it should generate a page with the 0,0,0 origin point in MoI corresponding to the bottom-left corner of the page. You should be able to draw in a rectangle of your page width and height with its corner at the 0,0,0 origin point to give you a preview of what is going to be on the page, then move your objects (while keeping the page rectangle in place) after each export to expose different areas to the visible page rectangle.
The "Center on page" option is here:
