MOI5 Wish list
10289.10 In reply to 10289.9
Hi Salvatore,
> The poster option in Acrobat is not suitable for the "print+glue+cut" approach, because it's
> too precise. I need to have 10-15mm minimum of overlap in each sheet and the possibility
> to add a border, so that I can precisely overlap the sheets when stick them together.
There is an overlap option in it which sounds like what you are describing:
https://helpx.adobe.com/acrobat/kb/print-posters-banners-acrobat-reader.html
> I know I could move all the pieces together, but I just don't like to move parts around
> just to export a PDF, unless I have few of them.
I could cook up a plugin for you that would let you pick some points and then handle the moving for you and generate one PDF file for each page origin point that you picked, would that be helpful?
> I also notice while I was preparing this quick example that if I select a Point and click on Details
> it doesn't show nothing in the object properties, it would useful to actually show the x,y,z position.
I've been meaning to do that, the part that is a little tricky is I want it to work for both showing and also setting the point as well.
