Creating a 3d solid of a non-symmetrical curved shape
10286.4 In reply to 10286.1
You can Sweep the green Profile using the red & blue curves as Rails. Then pick the orange curve as a Scaling Rail.
Scaling Rails are nice because you can define the shape as a continuous, rather than discrete curves.
And if you turn on points, you can modify the scaling rail and see the model update in real time.
Note that the orange Scaling Rail does not have to touch the green profile curve. The profile curve will stretch to meet the scaling rail as it sweeps.
You can also add additional green Profile curves if you need a more complex shape on the bottom, but in this example it looks like a simple rounded bottom is all you need.
Finally, if you want a Solid, just draw the green Profile as a closed curve.
EDITED: 24 Apr 2021 by EDDYF
